More 20mm Masters in the Pipeline from WarTime Miniatures
Gossip about upcoming products and all other general miniature discussion.
Post by Admin Fella » Fri Jan 29, 2016 5:43 pm
Hello All
Below are some more 20mm releases in the pipeline.
Late War FJ with MP44
Late War FJ Command Set
Volkssturm Pak Crew
Volkssturm Panzerfaust
German Feldgendarmerie
For Modern fans I am still working on a new range of Modern Aussie SF. This range will be done in 28mm and 20mm. Here is a few of the 3d renders. The overall plan is to re release all my moderns using this medium which will make them (all going well) the finest (I think) 20mm moderns available.
Don't forget to check out WarTimes existing Late War FJ range, Late War US Army and many others, particularly with more pending Battlegroup releases. ;)
P.S: The Volkssturm and Panzergrenadier Tank riders are the first of the "Fall of Prussia" range. I am currently looking at making Volksgrenadiers for the next release. What do you think?
http://www.wartimeminiatures.com.au
Re: More 20mm Masters in the Pipeline from WarTime Miniatures
Post by Dropbear » Sat Jan 30, 2016 6:01 am
those 28mm & 20mm moderns are very interesting. Without giving away too much, will they only be Aussies/SF that you are making, or other types of Aussies and other nations too?
Post by Admin Fella » Sat Jan 30, 2016 8:33 am
Hello Mate
They are the first of several nations planned. A real test project to try out the process, style, costs etc.
I do hope to do allot more this way, but will wait and see.
Post by Dropbear » Sat Jan 30, 2016 9:36 pm
Cheers.
The detail on them is fantastic, and if that can translate into that actual miniatures they will certainly look the part.
Post by Admin Fella » Sun Jan 31, 2016 2:50 pm
The printer is confident they will translate nicely. I have a 28mm sample and it even prints the boot tread.
It is a jewellery quality 3d printer, not a cheap option for making figures, but sometime quality is worth it.
