Australian Napoleonic Congress 2011
All of the projects start small but normally end up huge!
Moderator: Bluewillow
Postby Bluewillow » Sat Nov 12, 2011 8:10 am
"Australian Napoleonic Congress"
All things Napoleonic
Saturday and Sunday 19th and 20th November
Goulburn Soldiers Club
Cnr Market and Sloane Street
Goulburn NSW
This year we are returning to the original format with guest lecturer, wargaming , re-enactors and a period styled dinner.
Most of the games this year will revolve around the 200th anniversary's of the 1811 campaigns.
Our Goal is to achieve a well rounded event that will satisfy all Napoleonic enthusiasts, I hope to see you all there!
Booked and confirmed
1812 Battle of Lundys lane (saturday)Mark and John Primrose (Black Powder) seeking gamers 4-6 players
1812 battle of Fort Erie (Sunday) Mark and John Primrose (Black Powder) seeking gamers 4 – 6 players
Château d'Hougoumont 1815 Colin Graigie (General de brigade ) seeking gamers 4-6 players
Battle of Villanueva de los Castillejos January 24 1811 Saturday 28mm GVS (In the Grand Manner) seeking gamers- 6 to 8 players
Battle of the Gebora 19 February 1811 Sunday 28mm GVS (In the Grand Manner) seeking gamers- 6 to 8 players
The Battle of Lissa 13 March 1811 Naval Napoleonic CGS (1/1200th Naval Saturday) seeking gamers 2-4 players
Battle of Tamatave (sometimes called the Battle of Madagascar) 20 May 1811 Naval Sunday GVS (1/1200th naval) seeking gamers 2-4 players
Battle of Tippecanoe November 7, 1811 (skirmish) GVS (Brother Against Brother 28mm) seeking gamers 4 – 6 players
Battle of Albuera, 16 May 1811 28mm (Black Powder ) seeking gamers 6-8 players
Marshals Baton painting Competition
Large Figure or bust (54mm or above)
28mm Command (one or more figures on a command or display base)
15mm command (one or more figures on a command or display base)
28mm diorama any theme (more than four figures)
15mm diorama any theme (more than four figures)
28mm Army (three or more units)
15mm Army (three or more units)
braille scale army (smaller than 15mm, three or more units or ships)
cheers
matt
Re: Australian Napoleonic Congress 2011
Postby Bluewillow » Sat Nov 12, 2011 8:11 am
Marshals Baton painting Competition sponsored by War and Peace Games
CONTEST DEFINITIONS AND JUDGING
1. All entries MUST BE YOUR OWN BRUSH WORK!
2. JUDGING. Models will be judged for skill in construction, finish, realism, scope of effort, and accuracy. Additional criteria are considered for special categories such as dioramas and collections. Models are judged as three-dimensional objects and are examined in all aspects. Entries will be handled, by judges both for proper table placement and for judging, as required. Models in the Contest Room will be covered by glass display cases while on general public display. Judges will not remove cases from models unless the modeler has given explicit, written, approval in advance. The following is an exception to this rule. In instances where removal of a case could cause damage, and in the judgment of the respective Head Judge the case would not impede effective judging, the case may be left on for judging. This arrangement must be made prior to judging and noted in writing on the entry form by the Head Judge.
3.BASES/DIORAMAS. Bases will be allowed in all categories and will not be considered in the judging except in the Diorama classes. A base may be a piece of undecorated wood, plastic or glass or it may simulate the natural surface on which the representation would be found; however, nothing other than that surface may be used. Military vehicles may rest on simulated ground or paving, Ships may be displayed on a water effect base. The base must not be the predominant feature of the entry and must be of a size proportionate to the model. The model may include primary figures. The addition of any other figures or equipment outside or not attached to, the model (e.g., support equipment, or buildings) may make the model a Diorama, which must then be entered in the proper Diorama category. Dioramas are judged not only on the technical merit of their construction but also on the strength of the theme or story they present, so that if two dioramas were technically equal the one having the stronger theme or story would win.
4.JUDGES. A Chief Judge must be chosen and he must brief all judges before the contest judging. Only Judges fully registered at the Convention are eligible to join judging teams. Judges may not judge a category in which they are entered. Judging teams will be composed of multiple judges, preferably representing different scales. Strict impartiality will be observed, and violators will be removed from judges' lists for future Conventions. Any judges disqualified for cause may not assume any role related to the contest at future Conventions and may not be present in the room during the judging for any reason. This will include, but not be limited to, administrative, scoring, photographic and other support responsibilities. Judges will be provided with a special ribbon or other device to allow their easy identification during the convention. Specially designated judging teams will monitor the contest entries prior to judging to ensure models are in the proper categories for judging. They will also move models to accomplish the "splits" required in the larger categories.
5.ALL JUDGES' DECISIONS ARE FINAL. Contest registrars will help determine proper entry categories for models during registration, but final category placement is at the discretion of contest judges. Judges may split categories during final judging.
6 AWARDS. First, second, and third place awards will be given in each category. Individual contestants are eligible for only one award per category entered, i.e. no "sweeps."
7. No liability for loss or damage to contest entries is assumed by Goulburn Valiant Stormer's, the convention location, or the contest judges.
Postby Bluewillow » Tue Nov 15, 2011 1:39 pm
Afternoon all
I need numbers for Australian Napoleonic Congress Dinner on the 19th (Saturday night) we will be dining at the Fireside Inn, a Restaurant in old English style with a themed menu (TBA on wednesday, depending upon numbers) partners are encouraged to attend, approx cost per head inc entree, main and desert $40-$60 each depending upon selection. A great selection of wines, beers and spirits will also be available. Dinner is booked for 7pm, anyone who has period costume are encouraged to wear it!
so far I have confirmed numbers of eleven people and I need final numbers by tuesday afternoon.
matt
Return to “The Goulburn Club's Room”
