White frosting from Tamiya flat varnish
glenn_simpson
a Shandy
a Shandy
Enter a number between 90 and 100: 98
Post by glenn_simpson » Tue Apr 08, 2014 7:25 pm
When using Tamiya Flat spray can varnish to seal the paint and transfers on a finished plastic/resin/metal model, sometimes this results in white powdery or a white lumpy finish. Why does this happen? How can it be fixed? I have had some success in painting on petroleum thinner which seems to remove it gradually.
Best wishes,
Glenn Simpson
Gold Coast, Australia
g.simpson@hia.com.au
Re: White frosting from Tamiya flat varnish
Post by Admin Fella » Tue Apr 08, 2014 8:32 pm
I have had that sometimes and I think it can be as a result of the weather conditions. Too much humidity i think.
Stradiot
Post by Stradiot » Thu Apr 10, 2014 10:01 am
Glenn
Like others I will not spray on either a wet or humid day (might make it problematic on the Gold Coast). Others may spray outside but then take the figures into a heated room.
Check out 'The Miniatures Page' web forum - if you do a search for varnish/frosting I am sure others have had similar problems and there were some solutions suggested. The 'Lead Adventure Forum' may also be a source of advice.
Good luck
Garry
