VK 6600 E-79 in 1/72
For all WWII Discussion
Alt Berliner
Post by Alt Berliner » Sun Apr 03, 2016 3:43 pm
I started this by requesting a friend of mine to make me a hull and turret to start from.
As per my request he sent me both these items,
they were both hollow being made from sheet styrene.
So I began by removing items that I felt were either incorrect or not needed,
and filled the turret and hull with resin to make them easier to work with.
these are the items I removed from his parts
this left me with this as my starting point
as you can see I filled them with resin, and opened the rear of the turret more.
Now...here I have replaced the frontal armor,
the engine deck, added a Tiger II cupola, and started work on the gun.
here I began building up the mantlet area with Milliput
this is after several layers of Milliput, and starting the carving it to shape.
Here you see the mantlet getting closer to the final shape
Getting closer
here I spliced loader's hatch into the roof, added a couple more items,
and started to mark out the details
I neglected to mention that I also grinded away the tail end (sides) to my desires.
here I gave the turret a coat of primer
I am trying to stay as close as I can to this drawing of the E-79,
while staying true to the Panzer front concept.
Here I began working on the front of the hull
as you see I have played with the periscopes, and added a vent fan to the hull roof.
I decided the open the hatches for the Driver and radio operator.
Here is the "lay out" for how I am doing the hull
This is how the Turret looks on the hull
here is an Over All view showing the the turret and gun in place.
well that is where I am for now.
Please tell me what you think.
Once the Pin is pulled......Mr. Grenade is not your friend.
Alt Berliner
Re: VK 6600 E-79 in 1/72
Post by Alt Berliner » Tue Apr 05, 2016 11:05 am
here I have done a couple more things
If you look closely at the front of the Hull Mount for the MG....
you can see it is bereft of detail.
So using my Jeweler's Engraving Tool I carved it out
I then drilled a hole for mounting the MG barrel, and a smaller one to represent the site aperture.
From here I turned my attention to the rear end of the hull.
now more than one example I have seen of the E-79 shows no exhaust pipes.
I cannot accept this, so using these examples of a 1/35 model,
I decided to go the same route.
here is my attempt.
My hope is that once all assembled.....
it will look much better
Alt Berliner
Post by Alt Berliner » Wed Apr 06, 2016 7:04 pm
In my emails someone has mentioned that this looks like an E-10....
I could not agree more......
In my mind I see a "big" E-10, but with a turret.
Alt Berliner
Post by Alt Berliner » Fri Apr 08, 2016 10:42 am
I have now worked out my "wheel spacing" for the running gear.
seeing as this was such a pain to do One (1) time.....
I will mold this and cast resin to make two sets.
Then I will have what I need for the Left and the Right sides.
Alt Berliner
Post by Alt Berliner » Thu Apr 21, 2016 11:50 pm
the more I handled the turret,
the more the chances grew that I would somehow screw it up,
or drop it, or something.
so I molded it and cast it in resin to be used throughout the final building of the model.
back to work :)
Alt Berliner
Post by Alt Berliner » Tue Apr 26, 2016 8:34 pm
OK......things are getting closer now :)
I am so itching to finish this one :)
Alt Berliner
Post by Alt Berliner » Mon Aug 15, 2016 11:36 am
OK....I have taken a Long Break from this.....
I think I am finally getting back into the swing of things.
I sourced out the parts I needed, gathered them together
and finally got it to all fit together (for one side).....
This is how it looks
This one side alone was an "All Day" project.....
so it's Break Time
Post by Captain Darling » Tue Aug 16, 2016 9:22 am
As per your other scratch builds very well done!
Pity once it gets on the game table allied air support will knock it out in seconds :lol:
Alt Berliner
Post by Alt Berliner » Fri Aug 26, 2016 4:26 pm
Many Thanks.....
Just to get your attention....
here are the tracks molded and cast in resin.....
this is the "first pull" from the new mold.
I will be back in a few min with some more pic's :)
Alt Berliner
Post by Alt Berliner » Fri Aug 26, 2016 5:34 pm
OK I still have a little ways to go....
But I think it will be done by the end of the Weekend :)
anyway I have taken the parts I have and test fitted them onto the hull.
I will then do a final inspection of the hull before molding :)
well this is where I am for now :)
Alt Berliner
Post by Alt Berliner » Fri Sep 02, 2016 2:22 am
OK except for the painting.... it is done
it has a few "quirks" I did not foresee.....
even though I "test fitted" the parts over and over again
but it is done.....
I will put it on ebay either later today, or tomorrow.
but here it is :)
Please tell me what you think :)
Alt Berliner
Post by Alt Berliner » Fri Sep 16, 2016 7:01 am
Well this is finally done......
it comes with a choice of two guns,
and can be built with either an MG34 or IR system.
it is now on ebay
so if you are interested one you can find it there,
or you can contact me directly :)
