1/56 VSF 'Zeppelin' Bomber Build - Update 9/6/17
Where you can chat and talk about everything not historical!
Post by Captain Darling » Sat Jan 07, 2017 8:35 pm
This is my take on on VSF Zeppelin/Airship Bomber, I have used Renaissance Miniatures Santos Dumont Airship #9 kit as a basis for it. I picked the kit up through a Kickstarter. The kit has saved me a lot of work as I was considering building something similar from scratch!
Here's the gondola I have to work on the balloon/envelope next :)...
The kit itself is good but if I was actually building the Santos Dumont Airship #9 I would have to make some improvements as I can't help but dabble; i.e. Adding a base to the basket, using a bit of dowel for the fuel tank, make a one piece engine block with better details using the kit radiator etc. Anyway a good kit not cheap and in my opinion not for the feint hearted.
Renaissance Miniatures:
https://renaissanceminiatures.com/webstore/
Santos Dumont Airship Instructions:
https://renaissanceminiatures.com/wiki/ ... ntable=yes
All the details of my changes to the Renaissance Miniatures Gondola and more pictures are on my blog...
http://captaindarlingsminiaturesemporiu ... t-one.html
Last edited by Captain Darling on Sat Jun 10, 2017 11:05 am, edited 4 times in total.
Re: 1/56 VSF 'Zeppelin' Bomber Build - Update 26/1/17
Post by Captain Darling » Thu Jan 26, 2017 2:26 pm
Hi All,
A small update on this kit build. Since I knew I would not be able to tissue and dope the ends of the envelope/balloon neatly I decided to make caps (thought of buying r/c plane spinners for the ends even but to hard to find the right size).
I made a paper template then cut 0.5mm styrene sheet bits that I glued to the envelope/balloon fame, I finished the ends with Milliput. Its not perfectly round the ends meet at the bottom in a slight V which looks like a keel so is fine for me  :)...
also seeing how well these caps look I Have decided not to go ahead with a tissue and dope finish for the rest of the envelope/balloon instead I'll individually cut the required 64 segments to cover it in 0.5mm styrene glue each on, add rivets and paint with a steel like finish and have an armoured envelope/balloon...
Here's where I'm up to...a quarter done...
How each panel is added, they each need to be secured while the glue sets to conform with the curve...
Cheers?
Post by Dropbear » Thu Jan 26, 2017 6:05 pm
This is looking good. Keen to see the finished result.
Post by Captain Darling » Tue Jan 31, 2017 8:05 pm
Thanks Dropbear!
Hold back on your excitement everyone important news...some more armoured panels added to the balloon/envelope ;)
Next step when I finally get to it is adding rivets to the armoured panels; now at least 6 rivets a panel and 64 panels...AW MAN!!!!!
Post by Dropbear » Wed Feb 01, 2017 9:15 am
good luck with the rivet counting :lol:
How much more to go after the rivets/panels?
Post by Captain Darling » Fri Feb 03, 2017 8:23 am
Thanks Dropbear...
Almost there, just got to do:
Attach 6 more panels
"grout" the panels
Sanding
Lots of rivets
Painting
Attaching gondola to balloon
Build Stand
:shock:
Post by Captain Darling » Wed Feb 08, 2017 5:33 pm
Did someone say rivets!
Okay completed balloon got a spray coat of black so I could see where to clean up excess glue and 'grout' from the panels then after that the adding of rivets began.
Now I was thinking 6 rivets a panel oh no that was way to few here's the breakdown:
32 panels of 10 rivets
16 panels of 7 rivets
16 panels of 5 rivets
512 rivets :roll:
I'll say it again...Awww man!
Current rivet progress...
Post by Midshipman Easy » Thu Feb 09, 2017 12:29 pm
Don't you just love those moments when you have this great idea, rush in to get it started and then find that some part of it just a complete grind? :D
Looking good. How many rivets to go?
Post by Dropbear » Thu Feb 09, 2017 1:20 pm
Midshipman Easy wrote:Looking good. How many rivets to go?
Maybe best not to ask... it might make him a rivet counter :lol: :lol:
Post by Captain Darling » Thu Feb 09, 2017 6:36 pm
Thanks gentlemen!
So far 22 panels done out of 64...mainly doing the panels with 10 rivets first up to ease the pain later :lol: ...
Post by Captain Darling » Sat Feb 18, 2017 6:36 pm
Hi All,
Some progress the balloon is virtually done, next step joining the gondola to the it!
Balloon all masked up for painting the black sections...
Balloon ready to join to the gondola, I was going to go with a steel finish but I've used that on my Martian Tripods so that was out of the question, I used grey like my other VSF flyers for the base colour...grey the colour of Victorian cities...oh and Captain Smith has appeared again!
Catch you all soon!
Re: 1/56 VSF 'Zeppelin' Bomber Build - Update 18/2/17
Post by Dropbear » Sat Feb 18, 2017 9:37 pm
Looks fantastic... I was wondering for a bit with the newspaper wrapped around it though :P
Post by Midshipman Easy » Sat Feb 18, 2017 9:49 pm
Looks Fantastic Capt.
Could do with more rivets! :D :) :lol:
Post by nevermore » Sun Feb 19, 2017 1:30 am
looking the bees knees, excellent job
Post by Captain Darling » Sun Feb 19, 2017 11:09 am
Thanks for the encouragement guys...more rivets...ahhhhhhhhhh!
So the gondola has finally met the balloon...instead of going with a 'fake support' I have substituted coat hanger wire for what should be 'cables'....
There'll be some more rigging to do yet, need to add some 'fabric' to the rudder and then it needs a base...hmmm suggestions welcome...my current thought is a couple of upturned plastic Martini glasses on a large base and the stems will run up through the gondola frame????
Re: 1/56 VSF 'Zeppelin' Bomber Build - 19/2/17 Gondola Connected to Balloon!
Post by Dropbear » Sun Feb 19, 2017 11:33 am
looking good now (well, it looked good before too)
Not sure what to suggest for the base though :?
Post by Midshipman Easy » Sun Feb 19, 2017 8:18 pm
I might have gone for plastic champagne flutes, but your idea sounds cool.
Post by Captain Darling » Mon Feb 20, 2017 6:32 pm
Thanks guys!
The plastic Champaign flutes did come to mind but I think the lower triangular Martini ones will have a bigger footprint to help stability...well that's the theory...get ready for tears :lol: ...
Re: VSF 'Zeppelin' Bomber Build - Update Stand Update
Post by Captain Darling » Tue May 30, 2017 9:49 pm
Okay I've been distracted from my VSF interests recently by some Napoleonic and WW II projects but after a call from my local plastics supplier that they had finally got some 10mm clear plastic rod in stock i'm back to my core interest!
I tried to use a single piece of rod to secure the Airship but the models weight distribution soon led me to using two rods (in a very slight 'V' shape) on a substantial base plate...but I think it's come out alright...
I can now finish detailing the airship and 'texture' the base!
This thing dwarfs the rest of my VSF flying machines!
A final update soon!
Cheers All!
Re: 1/56 VSF 'Zeppelin' Bomber Build - Update 9/6/17
Post by Captain Darling » Fri Jun 09, 2017 10:53 pm
Did I say a final update coming up? Well it still is but not quite yet...
I was going to add fabric/tissue paper to the steering tail fin but had a thought that I could use this to attach nationality markings...below you can see the Imperial German fin skin Blu-Tacked into place, I have made up British, Russian and French fin skins too, also included in this picture is the addition of the ballast sandbags these still need a bit of paint work...
Here's how the whole thing currently looks...
A couple of close ups of the base (a bit washed out looking for some reason?)...
Almost there!
Re: 1/56 VSF 'Zeppelin' Bomber Build - 30/5/17 Stand Progress
Post by Midshipman Easy » Fri Jun 09, 2017 11:22 pm
I love the ruined barn on the base. Lovely touch.
Post by Captain Darling » Sat Jun 10, 2017 11:06 am
Thanks Easy!
